Beta-1 still has some minor issues
This feeling is more like a problem caused by changes in the underlying layer of Windows
The same code is displayed normally in the Win7 system, and Win7+must correct the relevant coordinate parameters
The height also needs to be corrected in order to finally display normally (to be resolved)
Catsxp浏览器有字体削头现象
Skedaddle7713
Re: Catsxp浏览器有字体削头现象
现在的版本应该没有这情况了吧!以前的旧版本是有这情况
当然如果是电脑系统没有相关语言的字体包那也会这样
比如 win7默认不支持韩文
比如 win7默认不支持韩文
Jeffhere
- 来自: Seattle, WA USA
I can confirm using "--disable-direct-write" in 4.1.3 and the site works properly with symbols appearing normal.
thank you!
thank you!
Jeffhere
It worked in 4.1.3 beta 1. Today I updated to beta 4.1.3 beta 4 and the problem reappears!
What is the specific abnormal website? For testing and repairing purposesJeffhere 写了: 2024年 1月 4日 03:13 It worked in 4.1.3 beta 1. Today I updated to beta 4.1.3 beta 4 and the problem reappears!
Jeffhere
oh, I had another post but it must be in a different topic (my mistake).
wunderground.com
then go to the "wundermap" section...
or see if this works: https://www.wunderground.com/wundermap
wunderground.com
beta-5 is ok!Jeffhere 写了: 2024年 1月 4日 17:06 oh, I had another post but it must be in a different topic (my mistake).
wunderground.com
Upload later! Can you help test it again
- catsxp_screenshot_www.wunderground.com.png (17.9 KiB) 查看 41281 次
Jeffhere
yes, I can confirm the display issue is OK again. Thank you!
Jeffhere
on a different laptop, it's not working on beta 5, last good version 4.1.1
maybe has to do with the same issue why people are reporting clipped/blurry fonts, as they are also good when backing to 4.1.1?
