便携版如何更新
有只猫
Re: 便携版如何更新
帖子 有只猫 »
[quote=catsxp post_id=15576 time=1761276370 user_id=2]
不能启动的时候,在进程里结束catsxp所有进程也不能启动?
个人认为大概率是某个扩展导致的问题
试试先备份旧版数据
然后关闭旧版上所有的扩展,再覆盖新版看能否正常使用
[/quote]
发现就是\User Data\Default下的Preferences文件的问题,找gpt从旧版138的文件改成新版143里带的,覆盖过去就能打开了。但是谷歌账户掉了,重新登录同步一下就可以了。搞不清是啥导致的。
来自: Czech Republic
Re: 便携版如何更新
帖子 redfox »
It seems like the #1 problem described here viewtopic.php?t=5302 "1) sometimes it does not start, only two small catsxp.exe processes are present in Windows task manager; need to be killed manually and start again".
But it was a full setup version with installer.
Catsxp, is it possible that more recent versions (above 137) fail to update all user files correctly, including the Preferences file?
I spend much time setting up the right prefs values in the past, cannot imagine to start over.
有只猫
Re: 便携版如何更新
帖子 有只猫 »
redfox 写了: 2025年 11月 20日 00:50 It seems like the #1 problem described here viewtopic.php?t=5302 "1) sometimes it does not start, only two small catsxp.exe processes are present in Windows task manager; need to be killed manually and start again".
这个问题大概是从内核升级130或者132版本,提示高版本内核无法在低版本内核中正常使用开始出现的,不过我覆盖更新其他谷歌内核的浏览器是正常的,并且在论坛里没有看到其他人反馈相同问题。 不确认是不是个人原因,我的两台电脑都出现了这样的问题。第一次这个出现时,我选择不覆盖,重新使用,登录谷歌账号来同步相关内容,当我再次覆盖更新时又出现了,这次我配合chatgpt逐一排查,确认了是这个文件导致的,但是不清楚原理……
有只猫
Re: 便携版如何更新
帖子 有只猫 »
It seems this issue started around core version 130 or 132, when Catsxp began showing the warning that a newer core cannot run properly on an older one. However, other Chromium-based browsers update normally on my system, and I have not seen other users report the same problem on the forum.
I’m not sure whether it is something specific to my environment, but the same issue happens on both of my computers. The first time I encountered it, I avoided overwriting and instead performed a clean reinstall, then signed in with my Google account to sync my data. When I later tried to overwrite-update again, the problem came back.
With ChatGPT’s help I tested files one by one and confirmed that a specific file was causing the issue, although I still don’t understand the underlying reason.
(Translation assistance provided by ChatGPT.)
yal
Re: 便携版如何更新
帖子 yal »
这个问题在最近几个beta里似乎没有出现
来自: Czech Republic
Re: 便携版如何更新
帖子 redfox »
I will re-test after v5.12.2 is out.
