Win8 virtual machine test is normal!
3.3.5 beta-2 on W8.1 64bit
Re: 3.3.5 beta-2 on W8.1 64bit
- 2023-03-23_08-45-17.jpg (99.94 KiB) 查看 4615 次
I have no idea. But I found even though I always use portable version, catsxp littered through out Windows Registry. It's very likely the faulty versions used to run on this computer wrote something wrong into it. It's weird. But 110 based versions like 3.2.4 that still being able to download from you worked fine. 111 based original 3.3.3 used to work fine too. Your newly re-uploaded 3.3.3 doesn't, though.
p/s: you tested on a VM, my computer is a Intel(R) HD Graphics 4600, maybe this makes a real difference. Btw, I have never seen the error "GPU process launch failed: error_code=2" on this computer. So, it's very likely I don't need --no-sandbox at all. But it crashed for me regardless of having --no-sandbox or not anyway.
Update: it's weird why the original 3.3.3 worked but your newly re-uploaded 3.3.3 doesn't work. Given there is no changes in code, I guess there is something changed on your development environment that you didn't notice. I switched to Firefox anyway. I found Firefox is much smoother in graphics than catsxp. But the sound quality on Firefox is not as good as catsxp. Perhaps I have skipped Firefox too long to not realize how sluggish current Chromium kernel is.
Dump parsing is a c0000005 memory access error! But because the code has been changed, it can't be located in a specific location! Re-release the beta version without changing the code before it can be parsed! When is it convenient! Send another dump and I'll locate it
At a convenient time, help me test beta-5 and send me the dump as soon as possible, because it can't be parsed as soon as the code changes.s6nonqxt9y886fdp 写了: 2023年 3月 21日 08:46 Crashed regardless of having --no-sandbox or not. I tried adding --no-sandbox via both StartupParm.txt or catsxp --no-sandbox on the Command Prompt.
What the heck catsxp is doing on my computer? It added itself to the OpenWithList of various file extensions that completely have nothing to do with a browser, for example, it added itself to the OpenWithList of .7z and .cpp file extensions. I'm sure I have never manually added it to OpenWithList. This make me confused. My computer also has other browsers but none of them have such behavior.
p/s: it even added itself to OpenWithList of .001, .007 and .1 file extensions!
OK. This time I will not test with --no-sandbox.catsxp 写了: 2023年 3月 23日 21:38At a convenient time, help me test beta-5 and send me the dump as soon as possible, because it can't be parsed as soon as the code changes.s6nonqxt9y886fdp 写了: 2023年 3月 21日 08:46 Crashed regardless of having --no-sandbox or not. I tried adding --no-sandbox via both StartupParm.txt or catsxp --no-sandbox on the Command Prompt.
After tweaked the configs, now I have sound quality on Firefox as good as catsxp (or even better). I will definitely miss this browser but I'm happy with Firefox now.
看主页首页说明,沙箱功能目前无法兼容win7
csix
