Black page
Re: Black page
If dark themes are enabled
The dark theme is just a built-in plugin, regulated by its built-in rules
Re: Black page
catsxp 写了: 2024年 6月 8日 09:40 If dark themes are enabled
The problem still happens if both the Dark Plugin and the Dark Theme are not in use. It's something to do with the graphics internals of the browser; it failed to draw or render. My educated guess is that one possibility is that there is something wrong with the graphics internals; another possibility is that some obscure security feature like anti-canvas fingering is causing this.
Re: Black page
More information: The problem still happens if Ublock Origin is turned off. I tested with both Ublock Origin and Ublock Origin Lite. I even tested with a clean profile without any extensions installed and no modifications to the default settings are applied. The problem will sooner or later trigger after you are browsing for a while.
Re: Black page
Let's assume if it's really the Dark Plugin that is causing this (which I think is very unlikely), then this plugin is definitely broken because it's not doing its job, it only corrupts the display of the page. Why do you managed to ship such a buggy plugin as built-in?
