Error
Rag
Error
帖子 Rag »
6.2.2 Beta-6
I'm entering the address https://dzen.ru/ for the "Home" button, and an error occurs.
After this, the "Use default icon" function doesn't work.
The function doesn't respond when the button is pressed to turn it on or off.
As a result, the icon on the new tab is always the default.
Re: Error
Have you modified the language pack? Conduct a new unzip test
Only valid for the new tab extension. To enable or disable, you need to refresh or create a new tab
Rag
Re: Error
帖子 Rag »
catsxp 写了: 昨天 12:52 Have you modified the language pack? Conduct a new unzip test
Unzipped the new archive.
I didn't change the language pack.
I installed the new tab extension.
I refreshed the page and created a new one.
https://disk.yandex.ru/i/uz_37eArZNHbXQ
You can see everything in the gif file.
Re: Error
Waiting for repair
