Tab Search Button
分享点滴经验
ttomomo
Tab Search Button
帖子 ttomomo »
After updating to Ver: 5.7.3, I noticed that the "Tab Search Button" shows up occasionally on the Toolbar even when turned off in Settings and disabled in catsxp://flags/
Re: Tab Search Button
Settings Appearance
Turn off display
ttomomo
帖子 ttomomo »
I have mentioned that I already turned off "show tab search button" in Settings Appearance.
try
截屏2025-07-13 08.33.13.png (125.59 KiB) 查看 2793 次
ttomomo
帖子 ttomomo »
Still shows up, can't remove it.
Under normal circumstances, these settings are interconnected, and as long as one setting is in place, it will take effect. Please try setting up with a completely new configuration to see if it works
ttomomo
帖子 ttomomo »
Thanks for your help. Wouldn't like to try a completely new setting configuration, this is no big deal so just leave it as it is.
Rag
帖子 Rag »
ttomomo 写了: 2025年 7月 14日 09:22 Thanks for your help. Wouldn't like to try a completely new setting configuration, this is no big deal so just leave it as it is.
1.Settings\Appearance\Toolbar settings\Search tab - disable.
2.Settings\Appearance\Show "Search by tabs" button - disable.
And you will be happy.
帖子 333 »
Rag 写了: 2025年 7月 14日 12:44 1.Settings\Appearance\Toolbar settings\Search tab - disable.
yes, just turn it off in 2 places
ttomomo
帖子 ttomomo »
Thank you all, got it. I finally realize that I have to open "Customize your toolbar" from Settings\Appearance\ (OR open the sidebar) to turn "Tab search" off.
