Vertical tab UI issues
yylly
帖子 yylly »
The "+" icon for New Tab isn't adjusted when using dark mode:
FIXED IN BETA:
The position of the "New Tab" button becomes misaligned when closing a tab (toggling "Expand tabs" puts it into the position it should be in)
上次由 yylly 在 2025年 2月 12日 16:39,总共编辑 2 次。
I only speak English. If you don't understand what I say, please tell me and I will find a friend who speaks Chinese and English to help me translate.
( 我只会说英语。如果你听不懂我说什么,请告诉我,我会找一个会说中文和英文的朋友帮我翻译。 )
Re: Vertical tab UI issues
This should be a color matching issue
I considering whether to use distinct colors to distinguish them
In most cases, it is not necessary to fully display them
yylly
帖子 yylly »
catsxp 写了: 2025年 2月 4日 09:04 This should be a color matching issue
This wasn't a problem in builds from a few months ago, something changed.
Also, the alignment issue is separate from the color issue. The alignment issue also wasn't present in builds from a few months ago.
yylly
帖子 yylly »
The new tab misalignment problem is fixed, but the "+" button is still dark and can't be seen without hovering the mouse cursor over it.
