Catsxp 3.3.5 beta 1 W7 64 bit
Jeffhere
来自: Seattle, WA USA
帖子 Jeffhere »
"Win7: You need to add the startup parameter -- no sandbox to start normally (GPU process launch failed: error_code=2). After several days of checking, the cause of the problem was not found!"
When I enter the -- no sandbox parameter as instructed, Catsxp immediately crashes with no error message at all.
I removed the space between the 2 dashes and the first letter of the parameter, since all other default parameters have no space between the dashes and text like such
--no sandbox
Then I tried adding a dash between no and sandbox, since all the default parameters use a dash in between words, no spaces.
--no-sandbox
Now 3.3.5 beta 1 runs but prompts me the following info:
I am removing 3.3.5 beta 1 until further instruction is provided. Thanks for all your work!
Re: Catsxp 3.3.5 beta 1 W7 64 bit
--no-sandbox
Jeffhere
来自: Seattle, WA USA
帖子 Jeffhere »
yes, that was one I tried that allowed catsxp to run but with the warning, as you can see in the pic
I used an updated list (I assumed catsxp is based on chromium) at https://peter.sh/experiments/chromium-c ... -switches/
It's not recommended to use Chromium with --no-sandbox flag. People said Google themselves recommend using another browser than using Chrome without sandbox.
https://unix.stackexchange.com/question ... ndbox-mean
try beta-3
If there is an abnormal crash, please send the dump file to my mail
s6nonqxt9y886fdp 写了: 2023年 3月 21日 07:15 It's not recommended to use Chromium with --no-sandbox flag. People said Google themselves recommend using another browser than using Chrome without sandbox.
I know, but I can't confirm whether it's due to a sandbox code issue or other code that caused the sandbox exception! The Google kernel code has changed too quickly to know exactly what code they have changed causing these problems
