How to disable "Create QR code" button on address bar?
I'm an old-school man and I have no use of it. Sometimes I only wanted to click the star button to make a bookmark, I mistakenly clicked it instead and it's definitely not what I wanted. Please help.
Re: How to disable "Create QR code" button on address bar?
I want to disable right click -> Create QR Code for this page too.
incognito mode?
Hide the shortcut button on the address bar?
catsxp 写了: 2023年 2月 17日 07:39 incognito mode?
No. Any mode. I have no uses of this feature. I want to get rid of both the button on address bar and the menu entry on right click.
The new kernel integrates relevant buttons
catsxp 写了: 2023年 2月 17日 16:49 The new kernel integrates relevant buttons
Maybe you posted on the wrong thread? Btw, the image resolution is too low, I can't see anything!
s6nonqxt9y886fdp 写了: 2023年 2月 17日 01:25 I'm an old-school man and I have no use of it. Sometimes I only wanted to click the star button to make a bookmark, I mistakenly clicked it instead and it's definitely not what I wanted. Please help.
Still using the old version?
The new kernel will not display "Create QR code"
Because it has been integrated!
catsxp 写了: 2023年 2月 18日 08:53
Are you so sure about that?
Catsxp	3.2.5 Kernel: 111.0.5563.31 (Official Build) (64-bit)
Revision	422f1371d5d5058d24be73240195eb4c690f026a-refs/branch-heads/5563@{#518}
Update: in case you can't see attached images (I can't, have no idea why).
Image 3.png (8.5 KiB) 查看 4388 次
Image 2.png (11.6 KiB) 查看 4393 次
Image 1.png (13.3 KiB) 查看 4393 次
If you turn off the display of address bar ->shortcut button
The QR code button will be displayed
catsxp 写了: 2023年 2月 18日 15:17 If you turn off the display of address bar ->shortcut button
I don't understand what you said. As you can see, I didn't turn off the shortcut button (is there a way to turn off it I wonder? I don't see any options to turn it off!). I'm always in incognito window. That shortcut button, sometimes appears, sometimes not. On normal window, I can always see it.
If you mean the address bar then I don't turn off it either (I recall on Firefox it allowed me to hide the address bar but I don't see any options to do that on Catsxp, I also have no reasons to hide the address bar). See the attached image.
Why don't you simply tell me it's impossible to disable QR Code Generator integration? It's almost sure to be the case.
