Clear browsing data...
I know this minor bug since I started to use Catsxp. I believed it was fixed for a while before it came back again. It's annoying but it seems not affect the functionality of Clear browsing data..., I did see the disk space reclaimed after using Clear browsing data.... When I first know it, it kept telling Calculating... really make me afraid of the browser profile was corrupted, turned out nothing corrupted and everything is normal.
Back to the bug. It will keep telling Calculating... on Cached images and files regardless of how long you waited for it. But it seems it really cleared Cached images and files. On Chrome it should be able to correctly report the size of the Cached images and files to be removed.
p/s: I'm using Catsxp portable (I have always use Catsxp portable since I knew about Catsxp).
Re: Clear browsing data...
Thank you for your feedback and follow up the problem later
Portable?
Try to modify StartupParm.txt
--disk-cache-dir=../Cache
to
--disk-cache-dir=./Cache
Confirm fixed on 3.3.2
