3.12.2 x64 portable newtab page bug
Can't select either Turn on Catsxp News or No thanks. It's stuck. This will happen again and again with each newtab you opened.
Re: 3.12.2 x64 portable newtab page bug
The information source of the news is currently empty and cannot be used normally at the moment
catsxp 写了: 2023年 12月 8日 22:28 The information source of the news is currently empty and cannot be used normally at the moment
This is irrelevant. On previous versions up to 3.12.1, the dialog is also there, but it isn't being placed in the wrong position like it currently is. Don't you see it's moving up and overlapping with the stats? It doesn't do that on previous versions. And, as I recall, it's possible to choose to turn on or disable the feature on previous versions. On 3.12.2, the buttons are useless and I can't even select it.
I am unable to reproduce the error on the screenshot locally
catsxp 写了: 2023年 12月 9日 08:20 I am unable to reproduce the error on the screenshot locally
I'm using Windows 8.1 64 bit. Could you test on Windows 8.1 64 bit?
Please try clearing the cache
Test normal!
2023-12-13 185347.jpg (99.48 KiB) 查看 34236 次
The situation improved in 3.12.3 and I consider it as acceptable, even though the behavior is not the same as on previous versions. Btw, clearing of cache doesn't work. It only changed after I upgraded to 3.12.3. You always run the latest version, this is the difference between you and me.
