(Version 3.12.1) There is no distinction between the appearance of the 'active' and 'inactive' tabs in the Vertical Tab. (The 'active tab' apears much brighter when using the horizontal tab bar at the top).
Could you please make the 'active' vertical tab appears brighter?
Could you please make 'Active Vertical Tab' appears brighter?
ttomomo
Re: Could you please make 'Active Vertical Tab' appears brighter?
Please try switching themes with high contrast
ttomomo
That's OK after using a high contrast theme. Thanks.
