It should be the reason why the network disk server cannot be accessed normallyJeffhere 写了: 2023年 4月 13日 05:25 my workaround (downloading on phone)is not working now. Same exact action as my pc's.
猫眼浏览器(Win Release)
Re: 猫眼浏览器(v3.4.3 Release)
Jeffhere
- 来自: Seattle, WA USA
I am trying to contact 123pan to see if they can assist.
As noted, I can download files from all my other freeware software sites, only Catsxp can not download.
Jeffhere
fyi, just now I was able to download the recent beta zip file....yeah!!!
Hope it's an issue that was fixed, as opposed to "good luck"!
Jeffhere
3.4.4 beta 5 bug, was able to duplicate.
In this version, I see when you download a file, a separate download icon appears next to the download icon I have set on the toolbar.
If downloading a file (for example, the zip of the beta), if you stop the download (not pause it, but kill the download by using the "X" to stop the download), Catsxp crashes.
I tried with the standard toolbar download icon enabled or disabled, same thing. That secondary download icon that appears when downloading must be new as I never saw it before.
It also crashes catsxp, even when I just took a screenshot of the new icon...
Thank you, the next beta version is fixed.
Jeffhere
confirmed fixed, all is good now.
sth
Re: 猫眼浏览器(v3.5.1 Release)
Hi, is there an option to hide the "Use vertical tabs" button? Can't find it anywhere. Trying to click the Back button I always missclick and it's so annoying to uncheck it every time. And what is the dot over the "Search tabs" button? Is there a way to hide it? Thank you!
upd: oh, I have version 3.4.5, haven't noticed that, I thought I downloaded the latest one. Thanks!
上次由 sth 在 2023年 4月 26日 06:51,总共编辑 1 次。
Settings Appearancesth 写了: 2023年 4月 26日 03:08 Hi, is there an option to hide the "Use vertical tabs" button? Can't find it anywhere. Trying to click the Back button I always missclick and it's so annoying to uncheck it every time. And what is the dot over the "Search tabs" button? Is there a way to hide it? Thank you!
sth
I've been playing with it for 2 days and was thinking to switch as a primary browser. I really like it, it has all the features I need, well it's just perfect. The only drawback I noticed is the bug with center aligned icons when DirectWrite is disabled. I think it could be due to internal adjustments on fonts rendering. Can it be fixed somehow? Anyone has the same issue?
Here's the comparison with Cent:
Here's an example of google fonts:
upd: checked the beta 3.5.2, the issue persist
上次由 sth 在 2023年 4月 27日 04:55,总共编辑 2 次。
