Don't know what changed but I am not able to download the latest beta 3.4.3 portble
I think the message is saying "download limits exceeded" but I believe it relates to the website.
I've been trying occasionally for 2 days.
猫眼浏览器(Win Release)
Jeffhere
- 来自: Seattle, WA USA
3.4.3 beta 2 portable won't download
上次由 Jeffhere 在 2023年 4月 10日 21:29,总共编辑 2 次。
Re: 猫眼浏览器(v3.4.2 Release)
Jeffhere 写了: 2023年 4月 10日 01:53 Don't know what changed but I am not able to download the latest beta 3.4.3 portble
Refresh Right-click menu
The third function menu
Jeffhere
I've been downloading the zips from when I started using the browser.
Not sure what you are instructing, but I always drill down the X64 file I want, then click the download button and it downloads. I tried refresh, right click...but if I use "save as", it wants to save the page as html/mhtml...
Not sure what "the third function menu" is...sorry.
it is recognizing the click (cursur changes for a second) but nothing happens....and I wait. nothing...
上次由 Jeffhere 在 2023年 4月 11日 09:29,总共编辑 1 次。
Clear the cache once and try again!Jeffhere 写了: 2023年 4月 11日 09:04I've been downloading the zips from when I started using the browser.
- 20230411105342.png (15.08 KiB) 查看 28730 次
Jeffhere
I tried that but it did not work. Further, I removed cookies from "123pan.com" which is the portable download site. Then I tried on another pc and got same result.
What I noticed: when hovering on the download link to the right side of the filename (on the right of "save to cloud" in the filename row), I do see the cursor starts as a hyperlink cursor, then when I click the download, it changes to a standard cursor, then shortly changes back to a hyperlink cursor.
so it recognized the click. Once or twice, I'll momentarily observe "waiting for 123pan.com......" bottom left side of browser, then it disappears.
Nothing is downloaded....like noted, it worked fine since day 1 I started using Catsxp, all good through 3.4.2. - tried on 2 pc's (both using W7) also tried doing same on 3.4.1 - same results. I am able to download other files from majorgeeks.com as an example (great software repository site).
Very strange to me. Could there be an issue because of my location in America?
Thanks! I'll test it in the win7 virtual machine later.
Jeffhere
great. I also tested on my wife's laptop which had a much earlier version and it did same - no download.
Tried on an alternate browser band got same 'no download' failure...
I hope you can confirm the issue. thanks as always for your support.
update: tried with my android phone just accessing the website the way I normally would and I was able to download the file.
update: When I try using a normal pc browser, the cursor changes for about 5 seconds but nothing happens...could it be because of W7 64 bit?
上次由 Jeffhere 在 2023年 4月 12日 04:37,总共编辑 1 次。
Test OK!Jeffhere 写了: 2023年 4月 12日 02:52 great. I also tested on my wife's laptop which had a much earlier version and it did same - no download.
- 20230412074344.png (141.98 KiB) 查看 26546 次
Jeffhere
wow, ok then...can't investigate what can't be duplicated. well I have a workaround, at least.
I occasionally get "The shared page download operation is frequent, please try again later" translated....is that saying I am trying too often so I am limited? I haven' tried too often, although when it is not downloading, I may retry a few times. I'll wait a day or 2 to see if that changes.
The difference i see between our downloads, is I have mine automatically, you have "ask" each time, I assume (since I never see the download prompt). I will set mine to "ask each time" and see if that changes anything. Thanks for your time...
Jeffhere
Re: 猫眼浏览器(v3.4.3 Release)
my workaround (downloading on phone)is not working now. Same exact action as my pc's.
