ping 43.203.178.185
ping 54.180.247.99
both fail
[3268:5996:0219/130807.318:ERROR:media\base\win\mf_initializer.cc:152] Failed to start Media Foundation, accelerated media functionality may be disabled. If you're using Windows N, see https://support.microsoft.com/en-us/top ... 3c9f6a4439 for information on how to install the Media Feature Pack. Error: Could not resolve imports for MFPlat.DLL: Не найдена указанная процедура. (0x7F)
[3268:5996:0219/130807.318:ERROR:media\base\win\mf_initializer.cc:108] Failed to start Media Foundation, accelerated media functionality may be disabled. If you're using Windows N, see https://support.microsoft.com/en-us/top ... 3c9f6a4439 for information on how to install the Media Feature Pack. Error: Error (0x13D) while retrieving error. (0xC06D007F)
https://legacyupdate.net/download-cente ... 1-kb968211KB968211 is the Windows Media Feature Pack designed specifically for Windows 7 N and KN editions (x64), which lack native media functionality. It installs Windows Media Player and related technologies. If the update shows as "not applicable," you are likely using a standard Windows 7 version that already includes these features.
Key Details for KB968211 (x64):
Purpose: Enables media capabilities (WMP, Windows Media Center, ActiveMovie control) for restricted European/Korean Windows 7 N/KN editions.
Applicability: Only installs on Windows 7 N or KN. If you have a standard "Home Premium," "Pro," or "Ultimate" edition, this update is not required.
Error "Not Applicable": If you receive this error, check if you already have Windows Media Player installed. If so, the update is unnecessary.
Installation Method: If you have the correct version, it can be installed via the Microsoft Download Center or sometimes through Windows Update.
If you are trying to fix media issues on a non-N edition, this update will not work.
