猫眼浏览器(Win Release)
OS:7+
bomz
Re: 猫眼浏览器(Win Release)
帖子 bomz »
it is C:\Program Files\CatsxpSoftware\Catsxp-Browser\Application\debug.log
Running Google Chrome with --enable-logging --v=1 enables verbose, detailed debugging logs (INFO, WARNING, ERROR, and VERBOSE1). This captures browser behavior in a chrome_debug.log file, which is crucial for troubleshooting startup issues, crashes, or rendering problems. The logs are saved in the user data directory.
USER\AppData\Local\CatsxpSoftware\Catsxp-Browser\User Data\chrome_debug.log
chrome_debug.zip
is the file available?
上次由 bomz 在 2026年 2月 14日 19:14,总共编辑 7 次。
1.taskkill /F /IM catsxp.exe
2.del C:\Users\bomzzz\AppData\Local\CatsxpSoftware\Catsxp-Browser\User Data\SingletonLock
First, clean up according to the above
Please ensure that the log file generated is started in a clean state
bomz
帖子 bomz »
I don't have such file or directory, but make batch file and start it with working CatsXP
bomz
帖子 bomz »
chrome_debug.zip
in archive fail log and success log
[4816:3460:0214/183015.936:ERROR:media\base\win\mf_initializer.cc:132] Failed to start Media Foundation, accelerated media functionality may be disabled. If you're using Windows N, see ... Error: Could not resolve imports for MFPlat.DLL: Не найдена указанная процедура. (0x7F)
[4816:3460:0214/183015.988:ERROR:media\base\win\mf_initializer.cc:108] Failed to start Media Foundation, accelerated media functionality may be disabled. If you're using Windows N, see ... Error: Неопознанная ошибка (0x80004005)
Missing system library file MFPlat.DLL
bomz
帖子 bomz »
Windows Media Feature Pack
上次由 bomz 在 2026年 2月 14日 19:54,总共编辑 1 次。
Try reinstalling the Media Feature Pack
Compared with the logs of a normal startup, your logs report an error related to this library file (err:0x80004005)
https://data.codecguide.com/windows_media_codecs.htm
bomz
帖子 bomz »
I search Media Feature Pack for Windows 7 more modern version.
I use MPC HC with included codecs pack.
Windows Media Format Runtime for Windows XP/Vista
This package installs all the codecs and runtimes that are required for playing the various Windows Media formats, such as .wmv and .wma files.
These codecs are normally already included with Windows as part of Windows Media Player. So you should normally only need this package if you have removed Windows Media Player or if you are using the special European N or Korean KN edition of Windows that does not include WMP.
Version 11 ~ 9.4 MB ~ Only for Windows XP / 2003 / Vista
need wmfdist11 x64 my 12 version, site 11 version
图片 图片 图片
上次由 bomz 在 2026年 2月 14日 20:22,总共编辑 4 次。
bomz
帖子 bomz »
as I remember during windows instal I install 10 Windows Media Player Cinema instead 11. perhaps this is reason
Please apply all the patches normally
屏幕截图 2026-02-14 202945.png (29.02 KiB) 查看 103 次
