Anoter users of chromium 136 in windows 7 os have issues :
https://github.com/e3kskoy7wqk/Chromium ... 2866233734
" -"@rafaelmattos1969, @idontyboi, if you're still affected by this issue, you're welcome to assist with testing these builds as well."
-Yeah, 136.0.7103.96 x86 is affected. The issue starts with 7083.1. 7077.0 works.
I have a Turkish (not English) Windows 7, maybe this causes it? What Windows language are you running on? I already have KB4019990 and KB3080149 installed."
An absolute disaster: illegible writing, illegible settings menu, accent color that hides the writing...
drimisone
Re: An absolute disaster: illegible writing, illegible settings menu, accent color that hides the writing...
Can you help test the two test versions laterdrimisone 写了: 2025年 5月 9日 20:53 Anoter users of chromium 136 in windows 7 os have issues :
Make an effort to fix the issue
drimisone
Mr @Catsxp, i already test the new version of Chromium-for-windows-7 i mean the new debug version: today i install chromium 136.0.7077.0, there is no issues, there is no problems, everything is ok, however there is problems with chromium 136.0.7083.1,
and of course i already test the previous stable version of Catsxp= there is problems, and i tested the new version of Catsxp Ver: 5.5.3 and there is problems sadly, I already explained that previously....
trydrimisone 写了: 2025年 5月 9日 21:11 Mr @Catsxp, i already test the new version of Chromium-for-windows-7 i mean the new debug version: today i install chromium 136.0.7077.0, there is no issues, there is no problems, everything is ok, however there is problems with chromium 136.0.7083.1,
https://vip.123pan.cn/1811655563/catsxp ... _4_1_1.zip
drimisone
Thanks Mr @Catsxp !
So now i download and install this version :
Sadly, the same display issues problems remain : some of content of web pages are unreadable, menu unreadable, accent color hide the writing .....
drimisone
UPDATE ;
i test the new debug version of Chromium-for-windows-7 136.0.7080.0 : there is no issues, there is no problems, everything is ok
https://github.com/e3kskoy7wqk/Chromium ... /tag/debug
drimisone
In debug section of Chromium-for-windows-7, Mr E3kskoy7wqk says interesting things about diagnstic of these issues :
"To investigate #47 and #38, we are performing a bisect to identify the commit that introduced the problem.
Initially, we are assuming the issue is unrelated to src/third_party/skia. If it is later determined that src/third_party/skia is involved, we will also conduct a bisect on skia.
All builds released here are 32-bit versions."
drimisone
URGENT:
When I tested the new Catsxp version sent to me by Mr @Catsxp : https://vip.123pan.cn/1811655563/catsxp ... _4_1_1.zip
The browser Catsxp opened normally, even though there were display issues, I was able to launch Catsxp. But now when I try to reopen Catsxp again, the Catsxp window appears briefly and then closes abruptly. I tried several times=the same behavior: the startup Catsxp window appears briefly and then closes abruptly. I hope this problem will be resolved please so I can continue testing the beta versions of Catsxp, thanks!
Attention: Please backup user data first. m137 uses a new data version to save user data. The new version of data cannot be used normally in kernels below m137drimisone 写了: 2025年 5月 10日 02:23 URGENT:
drimisone
Thanks Mr @Catsxp for this important advice!
Yes, I regularly back up my bookmarks to a micro SD memory card, and I wrote my passwords on a piece of paper, so backing up my data isn't that important to me. And after testing the beta version of Catsxp, I deleted all of Catsxp's hidden folders in order to reinstall the future new version of Catsxp on a fresh basis and avoid possible conflicts between the data of the different versions...
