An absolute disaster: illegible writing, illegible settings menu, accent color that hides the writing...
来自: Czech Republic
Re: An absolute disaster: illegible writing, illegible settings menu, accent color that hides the writing...
帖子 redfox »
If it was a GPU driver issue, previous versions of Chromium wouldn't work either. But they do, up to 135.
The new 136 core is buggy, the best we can do is to save our energy and wait for future versions.
New cores and features may cause compatibility issues with graphics card drivers from a long time ago
chrome://flags/#ignore-gpu-blocklist -》Enabled, can be used normally, indicating a graphics card driver issue
drimisone
帖子 drimisone »
UPDATE :
Very very good news, it seems we find the rigin of these problems !!!!!!
We hope please Mr @Catsxp will make the necessary to fix these problems, thanks !!
But to quickly summarize the solution to these problems:
Chromium 136.0.7071.1 does not have these issues:
https://github.com/e3kskoy7wqk/Chromium ... 6.0.7071.1
However,
Chromium 136.0.7083.1 does have these issues:
https://github.com/e3kskoy7wqk/Chromium ... 6.0.7083.1
here the explanation of the solution, i copy paste the solution found by Mr. @e3kskoy7wqk the developer of Chromium-for-windows-7 :
https://github.com/e3kskoy7wqk/Chromium ... 2862971652
https://github.com/e3kskoy7wqk/Chromium ... 2863554098
https://github.com/e3kskoy7wqk/Chromium ... 2863611444
"-It seems I have to use a binary search to find the problem. Over the next period of time, I will build many versions between 136.0.7071.1 and 136.0.7083.1 to identify which specific commit caused the issue. Since I cannot reproduce this problem, I need @trimechee's help to test. @rafaelmattos1969, @idontyboi, if you're still affected by this issue, you're welcome to assist with testing these builds as well.
@trimechee First, I need to confirm whether the issue starts appearing from version 136.0.7083.1 (i.e., 136.0.7071.1 does not have this issue, but 136.0.7083.1 do)?
-Good news!!!! I'm going to cry with joy and happiness!!!! I just installed the zip version of Chromium 136.0.7071.1, and Chromium 136.0.7071.1 does not have these issues !!!!!
Bravo Mr. @e3kskoy7wqk 💯 💯 💯 🥇 and thank you so much for finding the source of the problem!!!!
I really can't believe my eyes. I really thought it was the end of Chromium on Windows 7! So yes, Chromium 136.0.7071.1 has no display issues, everything is normal, there is no problems in Chromium 136.0.7071.1, the content of web pages, menus, etc., is displayed correctly!!!!
Now I have to delete the zip version of Chromium 136.0.7071.1 and install version 136.0.7083.1 to see if any problems appear !!!
Obviously we share this excellent news with Mr @win32ss and we thank him so much for his precious help and ideas to find solutions to this exciting mystery :)
another good news!
Mr. @e3kskoy7wqk, exactly as you thought, I just installed Chromium zip version 136.0.7083.1 and the display issues are back again : unreadable web page content, unreadable menu...
while Chromium zip version 136.0.7071.1 does not have any issues!
Well done, Mr. @e3kskoy7wqk! 💯 💯
you have accomplished the amazing feat of finding the source of this problem and I assume now you'll compare the code of these two versions of Chromium to find the source of these problems! We also inform Mr. @win32ss's about the progress in resolving this problem, hoping he will give us his important opinion about the origin of this problem, thanks !"
here the 2 chromium versions :
drimisone
帖子 drimisone »
it seems my post was not posted, i re-post again by precaution :
UPDATE :
However,
another good news!
来自: Czech Republic
帖子 redfox »
If this bug affects only Windows 7 users, I wonder if Chromium developers will be willing to fix it. It would be good to test Chromium 137 or 138, whether they are bad too or not.
drimisone
帖子 drimisone »
Mr @Redfox, i already test chromium 138 for windows 7 OS :
https://github.com/e3kskoy7wqk/Chromium ... 8.0.7157.0
but sadly, there is the same problems in chromium 136
drimisone
帖子 drimisone »
UPDATE :
Mr @e3kskoy7wqk says to me :
"I’ve started the bisect process. Please test whether version 136.0.7077.0 exhibits the issue.
https://github.com/e3kskoy7wqk/Chromium ... /tag/debug"
and here my response :
"Thanks Mr @e3kskoy7wqk for the new version ! 💯 💯
Si i install chromium 136.0.7077.0 , there is no issues, there is no problems , everything is ok !
Let's note very bad news, I said previously that Yandex is the last major company to support Chromium on Windows 7 OS, but I just reinstalled Yandex browser as a precaution and the automatic update service of Yandex does not work and it shows me a message that I must upgrade to Windows 10 to benefit from updates of Yandex browser which remains stuck at Chromium 128 on Windows 7, it's a disaster, our last hope to save our economies, save the planet from an ecological catastrophe of destruction of millions of Windows 7 machines is Chromium-for-Windows-7 and Catsxp and Firefox nightly and Supermium and R3dfox and GOOGLE_CHROME_Windows_7! and bravo huge thanks to our hero Mr E3kskoy7wqk for continuing to do what multinational behemoths like Chrome, Yandex, Firefox...cannot do!"
I estimated it will take another two to three hours to compile m137. Test two m137 beta versions later
来自: Czech Republic
帖子 redfox »
I just installed Catsxp v. 5.5.3 final x64, and there are no errors or dump files! Good.
All switches to default, with GPU acceleration enabled.
Recently I also installed MS updates KB4019990 and KB3080149, maybe it helped.
drimisone
帖子 drimisone »
Interesting !
Yes Mr Redfox , yesterday the developer of R3dfox browser also advises me to install these updates :
KB2533623 (Adds several kernel32 functions)
KB2670838 (Platform update, needed for some games and drivers)
KB4019990 (Installed with .NET 4.8, adds native compatibility for D3DCompiler_47)
i tried to install these updates but i have error messages, and i use windows 7 32 bits starter edition :
I downloaded and installed these updates, but sadly, I got error message:
"The installer encountered an error: 0x8 ......:
The specified service does not exist as an installed service."
I also got the same error message when I tried to install the other two updates...
上次由 drimisone 在 2025年 5月 9日 20:50,总共编辑 1 次。
