使用第三方下载工具下载的功能 闪退
Re: 使用第三方下载工具下载的功能 闪退
再帮测试一下 beta-11
hihi427
帖子 hihi427 »
beta10 不崩溃了 所以没有dump文件
但是使用外部工具下载功能还是不正常 点击后 什么反应都没有 内置的下载列表 下载工具的队列 都没有
尝试关闭浏览器的话会提示 有1项下载正在进行中 退出后再打开依然看不到这个下载项目
未关闭时会生成.tmp下载的临时文件 关闭后也就没了
[52644:51512:0423/191638.880:WARNING:chrome_main_delegate.cc(750)] This is Chrome version 124.4.4.8 (not a warning)
[52644:51512:0423/191639.001:ERROR:chrome_browser_cloud_management_controller.cc(161)] Cloud management controller initialization aborted as CBCM is not enabled. Please use the `--enable-chrome-browser-cloud-management` command line flag to enable it if you are not using the official Google Chrome build.
[52644:51512:0423/191639.001:WARNING:account_consistency_mode_manager.cc(79)] Desktop Identity Consistency cannot be enabled as no OAuth client ID and client secret have been configured.
[52644:51512:0423/191639.021:INFO:notification_helper_impl_win.cc(173)] Failed to get notification settings from toast notifier
[52644:51512:0423/191639.031:WARNING:browser_management_service.cc(128)] EnterpriseLogoUrl fetch failed with error code -1 and MIME type
[52644:51512:0423/191639.031:WARNING:external_provider_impl.cc(514)] Malformed extension dictionary for extension: eanbfhgjiglaihocidogfpfnfnkbioko.  Key external_update_url has value "", which is not a valid URL.
[52644:51512:0423/191639.031:WARNING:external_provider_impl.cc(514)] Malformed extension dictionary for extension: oiibmefkomopiagoeedgmahfgnnoaman.  Key external_update_url has value "", which is not a valid URL.
[52644:56020:0423/191639.031:ERROR:dat_file_util.cc(53)] GetDATFileAsString: cannot read dat file C:\Users\ThinkBook\Desktop\portable_x64_beta_124_4_4_8_10\User Data\kfccjfggmjndcomiakdamhplllepilok\1.0.0\list_catalog.json
[52644:51512:0423/191639.158:ERROR:filter_list_catalog_entry.cc(214)] Could not load regional adblock catalog
[52644:21716:0423/191639.163:ERROR:dat_file_util.cc(53)] GetDATFileAsString: cannot read dat file C:\Users\ThinkBook\Desktop\portable_x64_beta_124_4_4_8_10\User Data\mkohloaccnliialcdhpgljfckmcphpaf\1.0.9\1\clean-urls.json
[52644:56020:0423/191639.163:ERROR:dat_file_util.cc(53)] GetDATFileAsString: cannot read dat file C:\Users\ThinkBook\Desktop\portable_x64_beta_124_4_4_8_10\User Data\mkohloaccnliialcdhpgljfckmcphpaf\1.0.9\1\https-upgrade-exceptions-list.txt
[52644:51512:0423/191639.175:INFO:greaselion_download_service.cc(98)] Greaselion encountered an unknown precondition: github-tips-enabled
[52644:51512:0423/191639.175:INFO:greaselion_download_service.cc(98)] Greaselion encountered an unknown precondition: reddit-tips-enabled
[52644:51512:0423/191639.175:INFO:greaselion_download_service.cc(98)] Greaselion encountered an unknown precondition: twitter-tips-enabled
[52644:51512:0423/191639.198:ERROR:CONSOLE(3)] "Unchecked runtime.lastError: Could not establish connection. Receiving end does not exist.", source: chrome-extension://cclklclghjmfaepdfdlppbgkpbocbbll/_generated_background_page.html (3)
[52644:51512:0423/191639.251:INFO:CONSOLE(1)] "loaded [object Object]", source: chrome-extension://cclklclghjmfaepdfdlppbgkpbocbbll/out/catsxp_dark_background.bundle.js (1)
[52644:51512:0423/191639.263:INFO:CONSOLE(265)] "这是一个最好的时代,
科技的发展给予了每个人创造价值的可能性;
这也是一个最充满想象的时代,
每一位心怀梦想的人,终会奔向星辰大海。
百度与你们一起仰望星辰大海,携手共筑未来!
", source: https://pss.bdstatic.com/r/www/cache/static/protocol/https/global/js/all_async_search_907346f.js (265)
[52644:51512:0423/191639.264:INFO:CONSOLE(265)] "%c百度2023校园招聘简历投递:https://talent.baidu.com/jobs/list color:red", source: https://pss.bdstatic.com/r/www/cache/static/protocol/https/global/js/all_async_search_907346f.js (265)
[52644:51512:0423/191639.278:INFO:CONSOLE(1)] "Site is not inverted: https://www.baidu.com/", source: chrome-extension://cclklclghjmfaepdfdlppbgkpbocbbll/out/catsxp_dark_background.bundle.js (1)
[52644:51512:0423/191724.310:INFO:CONSOLE(1)] "Site is not inverted: chrome://downloads/", source: chrome-extension://cclklclghjmfaepdfdlppbgkpbocbbll/out/catsxp_dark_background.bundle.js (1)
[52644:51512:0423/191731.171:WARNING:pref_notifier_impl.cc(41)] Pref observer for media_router.cast_allow_all_ips found at shutdown.
调试文件也没之前的错误了
hihi427
帖子 hihi427 »
hihi427 写了: 2024年 4月 22日 19:38
catsxp 写了: 2024年 4月 22日 18:34 等下帮测试一下Beta-7
这个崩溃和这几天其他用户遇到的的崩溃源是一样的原因,新核有指针检测,如果默认关闭,则它在异常的时候不会崩溃,但这显示并不符合安全规范!
尽量不关闭它,并修复崩溃源
能大佬暂时给一个选项 关闭这个指针检测 待修复后 用户自己再手动打开吗?
至少能保证一些功能正常使用
beta11 测试结果 跟beta10 现象一样
有否尝试停掉所有的扩展与脚本再进行测试?
停掉指针检测,没啥用!
指针检测不能通过的问题应该是解决了,因为已经不崩溃了!
试试,不调用 IDM 随便调用一个exe程序,看那个被调用的exe程序能不能正常启动
注意,也有可能是程序路径问题,理论上支持所有路径,
尝试复制IDM文件夹到如D盘根目录下,看能否正常调用
cent2cat
帖子 cent2cat »
我试了一下,确实使用第三方下载工具会闪退。
cent2cat 写了: 2024年 4月 23日 19:53 我试了一下,确实使用第三方下载工具会闪退。
beta-11?理论上应该不会再崩了!
我本地测试好多次,包括在虚拟机win7系统下,都没崩...
Dump发我邮箱,我解析跟踪一下!
hihi427
帖子 hihi427 »
catsxp 写了: 2024年 4月 23日 19:29 有否尝试停掉所有的扩展与脚本再进行测试?
停掉指针检测,没啥用!
每次测试 都是全新便携版 都是新的用户配置文件 没有任何扩展脚本
beta11 尝试调用d: c:根目录下 任意exe程序 都不能正常启动 (下载路径 exe文件路径 都放根目录 也没用) 现象跟之前LS描述的beta10状态一样
我尝试的是下载百度首页的logo图片, 右键图片另存为
选择第三方exe 点击下载后没任何反应,点击关闭浏览器提示有一项正在下载中 是否关闭,查看浏览器内的下载管理器 没列出该文件,
再点图片另存为 或者链接另存为等 下载操作,也都没反应了 跟没点一样 一点反应都没有。每次点击下载目录都有tmp文件生成,但是文件不会被下载完成, 列表也是空的
再次打开浏览器,自带下载列表里也啥都没有。
确认一下:
用内置的下载 可否正常下载?
下载保存路径里的文件夹是否正常且可访问
提示有下载并没有下载是正常的,因为没有成功调用第三方下载工具,下载回调处于暂停状态,成功调用第三方后,才会自动取消该回调
这情况很象是 下载保存路径的问题
尝试指定下载保存路径到有效且存在的目录文件夹下
hihi427
帖子 hihi427 »
catsxp 写了: 2024年 4月 24日 09:20 确认一下:
用内置的下载 可否正常下载?
下载保存路径里的文件夹是否正常且可访问
这情况很象是 下载保存路径的问题
内置下载工作正常,下载保存路径可正常访问
尝试更换过下载路径以及三方软件路径 都是一样的结果
也在其他电脑上尝试了 同样问题
上次由 hihi427 在 2024年 4月 24日 09:34,总共编辑 1 次。
帮测试一下 beta-13
使用的是个人电脑 还是 公司一类的受控电脑 ?
