beta-3 fixedPetrovic 写了: 2023年 5月 17日 04:08 v3.5.5 Beta-2
catsxp://settings/toolbar
Multi-column display - not works
内核推进至M145
Re: 内核提前推进至M114
sth
Re: 内核提前推进至M114
I've downloaded the latest beta and noticed that on some sites (and pages) the web fonts are not rendered with DW disabled. Instead the local font is picked.
The issue appears here: https://www.cdnfonts.com/kindmight.font
Here how it looks on gdichromium or cent:
There's yet another font rendering issue (not to mention that one) related to DW, <em> tag and web fonts, but I won't bother you right now.
Re: 内核提前推进至M114
Testing on the Win7 system, DW is on or off, the font will display an exception! Unknown reasonsth 写了: 2023年 5月 19日 00:12 I've downloaded the latest beta and noticed that on some sites (and pages) the web fonts are not rendered with DW disabled. Instead the local font is picked.
sth
Re: 内核提前推进至M114
Yes, it's Win7 x64 with DW offTesting on the Win7 system, DW
Re: 内核提前推进至M114
Request the following resources
https://fonts.cdnfonts.com/s/98122/Kindmight-0WRe9.woff
https://www.cdnfonts.com/site.webmanifestRequest normal under Win10 system
ExiledRose
Re: 内核提前推进至M115
Hello, I have been using Catsxp since April & on windows 7 & just wanted to say thank you for maintaining support for windows 7.
I decided to check out M115 (v3.6.4 Beta-2) to see whats new & I get a error message saying the browser is no longer supported on this version of windows. I am using windows 7 x86 (32 bit) so I am using the x86 version of the browser & I see no one has posted about this, so figure I would let you know.
Hopefully you are able to fix this because I love the browser & hope you are able to maintain windows 7 support.
Also I am a user from the U.S. so I sadly don't know Chinese & hope that's OK.
- Capture.PNG (37.59 KiB) 查看 39185 次
上次由 ExiledRose 在 2023年 6月 17日 04:21,总共编辑 4 次。
Re: 内核提前推进至M115
Win7 virtual machine testing is normal. Is there a custom group policy for the system?
Personal computer or company computer?
ExiledRose
Re: 内核提前推进至M115
Not that I know of truthfully, I mean if it helps I just did a clean install of windows 7 SP1 x86 (fully updated).catsxp 写了: 2023年 6月 17日 07:19 Win7 virtual machine testing is normal. Is there a custom group policy for the system?
Also I just tried portable M114 (x86) & that loads up without issues. So I tried M115 (x86) again after deleting m114 & get the error message windows version is not supported, then tried running as an administrator & it still got the windows version unsupported message.
So eh truthfully no idea why M114 (x86) works but not M115 (x86). Is there anything I can try on my end?
Edit: If it helps here is pictures showing M114 (x86) portable works & that it creates the user files/folders.
- Capture 2.PNG (19.86 KiB) 查看 39157 次
- Capture.PNG (19.01 KiB) 查看 39157 次
上次由 ExiledRose 在 2023年 6月 17日 08:03,总共编辑 3 次。
Re: 内核提前推进至M115
Incorrect packaging of x64 files into x86!
try beta-3!!
try beta-3!!
ExiledRose
Re: 内核提前推进至M115
It works, thanks for fixing the issue, I greatly appreciate it &I hope you keep up the amazing work.
- Capture.PNG (16.49 KiB) 查看 39146 次
上次由 ExiledRose 在 2023年 6月 17日 08:42,总共编辑 2 次。
