Please correct.
Re: Please correct.
帖子 333 »
catsxp 写了: 2025年 10月 20日 19:00 Can you help test if m142 Chrome is working properly?
i tested Google Chrome Portable Dev 143.0.7475.7
it have the same problem like Catsxp. it's chrome problem not CatsXP
Re: Please correct.
333 写了: 2025年 10月 20日 19:08
thank!
Waiting for Google to make official corrections
Most likely, it's still a compatibility issue with the graphics card driver
After the catsxp kernel upgrade, take some time to help test it again
Rag
Re: Please correct.
帖子 Rag »
Google Chrome 142.0.7444.34 portable.
The frame is the same as in CatsXP.
There is no blinking when right-clicking.
Re: Please correct.
Rag 写了: 2025年 10月 20日 19:30
It is caused by the same reason. Thank you for testing
Rag
Re: Please correct.
帖子 Rag »
Windows-10
v5.11.1 Бета-2
The same as in the previous beta version.
Re: Please correct.
It's a kernel issue, waiting for Google's official fix
Beta-2 has not upgraded the kernel and the issue has not been fixed
Re: Please correct.
Try beta-4
The kernel has undergone a minor upgrade, and it is uncertain whether Google has officially fixed the issue. If there are still problems, we can only temporarily adjust the parameters and wait for further repairs
Re: Please correct.
帖子 333 »
catsxp 写了: 2025年 10月 21日 17:25 Try beta-4
beta-4 same problems. yeah. waiting fix from google..
Rag
Re: Please correct.
帖子 Rag »
No. Nothing has changed. 图片
Rag
Re: Please correct.
帖子 Rag »
5.11.1 Beta-7
All good! Bugs fixed.
