cloudflare无限真人验证
Re: cloudflare无限真人验证
我测试是正常的,给个会无限验证的网址,我本地测试一下!
macyoyo
帖子 macyoyo »
https://manus.im/invitation
最近比较火的manus人工ai注册页面,下边就是验证
欢迎来到穿墙导航cqdh.top
macyoyo
帖子 macyoyo »
官方给出的排查方案,不知道是否有思路
Challenge loops can happen for several reasons:
1、Network issues: Poor or unstable network connections can prevent the challenge from being completed.
2、Browser configuration: Some browser settings or extensions may block the scripts needed to execute the challenge.
3、Unsupported browsers: Using a browser that is not supported by Turnstile.
4、JavaScript disabled: Turnstile relies on JavaScript to function properly.
5、Detection errors: If Turnstile suspects bot-like behavior, you may encounter repeated challenges for verification.
欢迎来到穿墙导航cqdh.top
macyoyo 写了: 2025年 3月 7日 11:59 https://manus.im/invitation
测试正常!!并不会循环验证
drimisone
帖子 drimisone »
Ahh I just remembered something important, a few months ago I remember I was very happy and relieved to see a new feature appear in chromium in:
chrome://settings/privacy
I forgot the exact name of the option but it was an option that allows the browser not to be detected as a robot and to automatically pass the captcha test ! ...
unfortunately this anti captcha and robot verification feature has been removed
from chromium and I think the solution to avoid cloudflare problems is to reimplement this deleted function, thank you!
drimisone
帖子 drimisone »
UPDATE:
This is official, i find the origin of cloudflare problem in Catsxp, i go to supermium settings and i find this feature anti robot anti captcha which allows sites to verify that we are not robots and thus avoid captchas:
there is anti robot option:
Chrome://Settings/Contents/AutoVERIFY
But in Catsxp browser, i can't find this capital feature to avoid captcha:
I think our beloved Catsxp should implement this feature to avoid cloudflare re captcha loop, thanks :)
macyoyo
帖子 macyoyo »
我找到问题了,我吧所有插件禁用了,然后一个一个测试,发现 “暴力猴脚本”有问题,在排除了暴力猴的插件内容,是一个叫做“音视频增强脚本”的脚本文件造成,只要关掉就能正常验证了。
欢迎来到穿墙导航cqdh.top
