The last hope is lost. When I examine assets.json I found the newly added min variants of filter lists. For example:
https://ublockorigin.github.io/uAssetsC ... rs.min.txt
I don't know what they are but they seem to not use !include and have everything fused together, so the number of filter lists need to be added is significantly reduced. I tested and quickly found that they do not work with Catsxp Shields. There are still full of ads.
Here is assets.json for anyone want to mess with it:
https://github.com/gorhill/uBlock/blob/ ... ssets.json
I will stick with Ublock Origin.
How long can you keep supporting MV2?
Mr_Electro84
- 来自: France
Re: How long can you keep supporting MV2?
That's why I said :s6nonqxt9y886fdp 写了: 2024年 5月 13日 00:16 It works for you doesn't mean it works for me. I have seen a bunch of Wayland fanboys on Phoronix with exactly the same behavior. I ignored them so I will ignore you. [...]
And you probably are in this case, so there's no need to get carried away.Mr_Electro84 写了: 2024年 5月 12日 21:20 I know that the current system won't suit all users, who either have specific needs or want to go even further.
Mr_Electro84
Windows 11 - Catsxp 64 bit
Update: The min variants of filter lists are indeed partially working. They failed to block ads on Youtube. But they seems to work on other sites. I have never test if they work on mail.ru, though. I discovered a new bug of Catsxp Shields.
These are the min filter lists I'm using to emulate Ublock Origin:
https://ublockorigin.pages.dev/filters/filters.min.txt
https://ublockorigin.pages.dev/filters/badware.min.txt
https://ublockorigin.pages.dev/filters/privacy.min.txt
https://ublockorigin.pages.dev/filters/unbreak.min.txt
https://ublockorigin.pages.dev/filters/ ... es.min.txt
https://ublockorigin.pages.dev/thirdpar ... sylist.txt
https://ublockorigin.pages.dev/thirdpar ... rivacy.txt
https://malware-filter.pages.dev/urlhau ... online.txt
https://pgl.yoyo.org/adservers/serverli ... =plaintext
https://raw.githubusercontent.com/dimis ... bo.min.txt
Please exclude RuAdlist if you don't need it.
